Editing an Action List
Often you can use an existing Action List and only make minor changes, for example change the predefined values.
To edit an existing Action List
  1. Open the Action Lists dialog. Refer to Where to find Actions and Action Lists.
  2. Double-click the Action List concerned.
    Note: Alternatively, select the Action List you want to edit and click > Edit .
    If the Action List is fully locked, you will be asked to enter a password before you can see the content of the Action List.
    If it is partially locked, you will be able to view the content of the Action List, but you'll have to click the Lock icon and enter the password, before you can make any changes. Refer to Locking an Action List.
  3. Fill in the Properties section as required:
    • Select General Information and set the Action List name, your name and company and a description of the Action List.
    • Select Locking Information and choose the appropriate options. Refer to Locking an Action List.
  4. Design your Action List, i.e. add or remove Actions or change the attributes of an Action as required. Refer to Designing an Action List.
  5. If you have made all required changes, click OK.
    Note: If you want to change the attributes of multiple Actions, do not click OK until you have changed them all. Clicking OK will close the Action List Editor!
    The changed Action List will be saved in the Local database (folder).
You can now run the Action List.
