This topic explains how to generate a Report using the Enfocus Navigator. If you have configured the PitStop Pro Preferences (under General) to always display the Preflight Report (with a chosen report style), you only must run the Action List, Global Change or Preflight Profile with the option Show results: Always.
To generate a Report which gives an overview of the results of your Action List, Global Change or Preflight Check
For more information about the Report styles, refer to The Report.
The Report appears and the errors, warnings and fixes are listed on the first page.
you can now:
next to an error, warning or fix to select and highlight the
corresponding object in the PDF document. Remember that you can browse
through the affected objects in the Enfocus Navigator. It may be a good
idea to open at the same time the Enfocus Inspector to see more details
about a particular problem or to correct the problem immediately.
next to an error, warning or fix to see a Help topic. A dialog box may
appear, asking you where you wish to view the Help topic (Open Weblink).
If so, select In Web
Browser.
