The Set hierarchy path element allows you to modify the hierarchy location path (stored in the internal job ticket). This is useful to organize processed jobs in a folder hierarchy, for example based on the result or the date of processing.
This element provides particular actions to change the hierarchy location path. You can add, remove, or reverse segments (i.e. parts) of the location path. Note however that you cannot combine different actions in one Set hierarchy path flow element. Hence, you may have to combine different elements of this type in order to build the new hierarchy path.
New path (to be used to store the processed files): Server\Customer X\Output\dd-mm-yy
Set hierarchy path1 will be used to remove the Input segment (level 2) from the location path. This results in Server\Customer X.
Set hierarchy path2 will be used to add two new segments: Output (level2) and today’s date. This results in Server\Customer X\Output\dd-mm-yy.
