Switch will process the input as soon as the flow is activated.
The number of jobs being present in a folder is indicated on the canvas. This allows you to see how files move along a flow and where they are being hold.
If more than 100 jobs are present in a particular folder, Switch doesn't display the number, but instead displays the symbol for infinity.
If the icon appears next to a Problem jobs folder, the Problem jobs folder contains at least one file or file folder. This may be due to the fact that the job does not match the filters set on a Connection element.
If the icon appears next to a flow element for processes, there may be a problem with this element, for example a network error (so jobs can no longer be transported), or an invalid property.
If the icon appears next to a folder element, probably the backing folder is not accessible anymore, for example because it does not exist anymore, or because the local network connection is broken.
Carefully check the output.
button.
