There are two ways to change the color of text or line-art objects in
a PDF:
- If you want to use the "default" color profiles defined in the Preferences, use
the Enfocus PitStop Inspector.
This way, you can as
well change the other fill and stroke attributes of the object (e.g. switch
between solid and gradient fill or stroke, change the dash
pattern,...)
- If you want to use specific color profiles, use the Enfocus Convert
Color panel.
