category and
make sure Fill
or
Stroke
are
selected (depending on what you want to change).
The Enfocus Inspector displays the current color settings of the selected objects.
You can convert the color using the Enfocus Convert Color panel.
Refer to Converting a color using the Enfocus Convert Color Panel.
You can convert the color to a color you select from the User Swatches.
The cap style determines the appearance of the stroke at the end of a path.
The join style determines the appearance of the stroke at the corner points of a path.
| Cap style | Join style | ||
| Icon | Meaning | Icon | Meaning |
Butt cap |
Miter join |
Round cap |
Round join |
Projecting cap |
Bevel join |
set the Miter
Limit (Refer to Stroke attributes: Miter limit).With stroke adjustment enabled, all vertical and horizontal lines are rounded to an integer number of pixel thickness to give them the appearance of the same weight.
When several strokes with the same line weight are rendered at low resolution, their rasterization may result in lines of different widths in device pixels (with a difference of one pixel at the most). This effect depends on how the exact position in real numbers of these strokes intersects with the device pixel grid. For a better visual result, automatic stroke adjustment can be enabled. This will automatically counteract the rasterization effects where needed, by slightly changing the line weight and coordinates, thus producing lines of uniform thickness in device pixels.
Vertical and horizontal lines are not adjusted. When rendered at low resolution, you may see small differences in width.
.The unit depends on the value set in the Preferences.
