| 1 |
Buttons to switch between QuickRuns and other "presets" (Preflight Profiles , Global Changes
and
Action Lists ( ) .
| 2 |
A search field (allowing you to search for a particular QuickRun) and an Action menu
(allowing you
to organize the QuickRuns). |
| 3 |
A workspace, which displays the available QuickRuns. The QuickRuns are organized in
folders, called "databases". By default, the following folders can be found:
- Favorites in Tools Panel: QuickRuns Lists marked as your
favorites. This provides you fast access to the QuickRuns you need often.
- Recent: The 10 most recently used QuickRuns.
- Standard: The default QuickRuns installed with PitStop Pro.
- Local: QuickRuns edited and created by you, and saved locally.
| 4 |
The bottom part of the dialog shows the shortcut associated with the selected QuickRun.
This shortcut is assigned automatically when you add the QuickRun to your favorites (via
the context menu).
