Where to find QuickRuns in PitStop Pro
QuickRuns can be accessed via the QuickRuns dialog in PitStop Pro. Its location depends on your Acrobat version.
The following table explains how you can open the QuickRuns dialog.
OS/Acrobat Do one of the following
Acrobat X and later
  • In the menu bar, click PitStop Pro > QuickRuns .
  • In the Tools pane, click PitStop Process > QuickRuns .
Windows shortcut Press Alt+Ctrl+Q.
Mac OS shortcut Press Q.
Note: You can change these shortcuts by creating your own shortcut set. See Preferences > Enfocus PitStop Pro Preferences > Shortcuts.
QuickRun Favorites
QuickRuns that were added to your favorites can be accessed as follows:
Acrobat X and XI
  • In the menu bar, click PitStop Pro > QuickRun Favorites , and select a QuickRun.
  • In the Tools pane, click PitStop Process > QuickRun Favorites and select a QuickRun.
Windows Use the shortcut of the QuickRun favorite.
Example:
  • Favorite 1: Alt+Shift+Ctrl+A
  • Favorite 2: Alt+Shift+Ctrl+B
Mac OS Use the shortcut of the QuickRun favorite.
Example:
  • Favorite 1: A
  • Favorite 2: B
