When you create a QuickRun, you must select the Action Lists, Global Changes and/or a Preflight Profile you want to run on the currently opened document. As you cannot edit or change the content of Action Lists, Global Changes and Preflight Profiles from within a QuickRun, we recommend checking or preparing them first, before creating the QuickRun.
To create a QuickRun
The option New from allows you to select an existing QuickRun from the Standard database; New from file allows you to select a file (*.eqr) from your computer.
, and
select the Action List(s), one or more Global Changes, and/or the Preflight
Profile you want to add to your
QuickRun.
The Action Lists, Global Changes and Preflight Profile appear in the Run box.
or Move Down
button to set the sequence in which the Action Lists and
Global Changes should be run.
The Enfocus Navigator is a dialog which gives an overview of the changes performed by the selected QuickRun and enables you to generate a Preflight Report. This Preflight Report is a PDF document which displays preflight and general file information as well.
