Importing a QuickRun
You can import QuickRuns you received from other users, or which were created on another computer.
QuickRuns have file extension .eqr.
To import a QuickRun
  1. Open the QuickRuns dialog. Refer to Where to find QuickRuns in PitStop Pro.
  2. Click > Import/Export > Import . If you want to import multiple QuickRuns, you may want to group them into a folder and import this entire folder into the application. In that case, choose Import Group and select the appropiate folder on your system.
  3. Select the appropriate QuickRun.
  4. Click Open.
The imported QuickRun appears in the Local folder in the QuickRuns dialog. You can run and/or edit this QuickRun as required.
