Running a QuickRun
To run a QuickRun, i.e. to apply it to the document that is currently open
  1. Open the QuickRuns dialog. Refer to Where to find QuickRuns in PitStop Pro.
  2. Select the desired QuickRun.
  3. Click . The QuickRun is applied. Depending on your configuration, the Enfocus Navigator or the Preflight Report appears. For more information, refer to The Enfocus Navigator, The Report, and Generating a Report.
  4. Check the result of the QuickRun in your PDF document. If the result is not OK, choose Edit > Enfocus Undo QuickRun or click the Undo button . Change the content of the QuickRun as required. See Editing a QuickRun.
