| # | Description |
| 1 | Buttons to switch between Action Lists ( ) and other
"presets" (Preflight Profiles , Global Changes and
QuickRuns ). |
| 2 | A search field (allowing you to search for a particular Action List) and an Action
menu
(allowing you to organize the Action Lists). |
| 3 | A workspace, which displays the available Action Lists. The Action Lists are
organized in folders, called "databases". By default, the following folders can be found:
| 4 |
The bottom part of the dialog allows you to run the Action List selected in the upper part of the dialog. You must indicate on which page(s) the Action List should run and whether or not the results should be shown in The Enfocus Navigator. |
