We recommend entering your personal information (such as your name and contact details) in the Personal info category of the Preferences. After you have done that, the personal info will be added to all Certified PDFs you create or edit with PitStop Pro, allowing the recipients of your PDFs to contact you if they have any questions.
Note that this personal information is the same for all PDFs you create or edit. If you need to add PDF-specific information, (for each PDF separately), you should use the Job info category of the Enfocus Certified PDF Panel.
Refer to Providing a Certified PDF with job information
To set the personal information
You can check the personal information in a Certified PDF through the Enfocus Certified PDF Panel in Adobe Acrobat.
Refer to Viewing the Certified PDF info
Remark:
The Certified user is not only identified by the personal information; there is also a second type of user identification, i.e. the system information, which consists of the details of the person who registered PitStop Pro and information taken from your operating system, network and computer.
