Providing a Certified PDF with job information
You can add job information to your Certified PDF documents as required. This can be any kind of information about the PDF document which you would like to share with the person who will receive the PDF document. This can include, for example:
To provide a Certified PDF with job information
  1. Choose Certified PDF > Certified PDF.
  2. In the Certified PDF Info category, click Edit.
    The Edit button becomes active as soon as the Certified PDF workflow is started.
  3. Select the Job Info tab as required.
    Note: The information on the Personal Info tab can only be changed through the StatusCheck Preferences. See Setting the personal information. The information on the System Info tab cannot be edited.
  4. Fill in the name, company address and contact details of the recipient of the PDF document.
  5. In the Message text box, type additional comments or remarks for the recipient of the PDF document.
  6. Click OK.
