Adding PitStop Pro panels to the
Tools pane in Acrobat DC
The Enfocus PitStop Pro panels
are not shown by default. You have to add them manually to the Tools pane, in order
to be able to use the PitStop Pro tools.
To add the PitStop Pro panels
Open Adobe Acrobat.
In the toolbar at the top of the application, click
Tools.
In the search field below, type PitStop and click the
search icon .
The PitStop Pro
panels are listed.
From the list below the PitStop Pro panel you want to add
to the Tools pane, select Add.
The added PitStop Pro panel appears in the Tools pane (on the right).
Do this for all PitStop Pro
panels.
To add the Certified PDF panel as well, type Certified
PDF in the search field (step 3) and click
Add in the list below the search result.
To access the tools included in the PitStop Pro panels, do one of the
following:
Click the name of the PitStop Pro panel
concerned.
Right-click the name of the PitStop Pro panel concerned
and click Open.
In the Acrobat menu bar, click View > Tools > <name of the PitStop Pro Panel
concerned> > Open.
If another panel has been opened already, click the small arrow below
the name of the panel and select the PitStop Pro panel you want to
open (see screenshot below).
The tools are shown at the top of the document or on the right side
(PitStop Edit panel).
Note: If there is not enough room to display all tools,
you will see the following icon: ;
simply click this icon to see the missing tools.
