In your Certified PDF, you can add a link to the source file(s) on which the PDF file was
based, for example a Word document or InDesign or Photoshop files, ...
If you do so:
- The PDF recipient can easily find the respective source files.
- You can later check whether these source files have changed since the time at which the
Certified PDF workflow was started. If you wish, you can even "synchronize" your source file
with the edited PDF: you can apply the changes made to the PDF (and reported in the Edit Log)
to your source file.
To add the source files
Choose .
In the Original Documents category, click
Select the source file(s) the PDF is based on (e.g. a Microsoft Word file, an
InDesign file, etc.).
To select several files in one go, hold down the Ctrl
key while selecting.
Tip: Remember that the location and the file name are stored in the PDF, so
make sure the location and the name are final before adding the source
file.
Click Open.
The name of the source file(s) appears in the Original Documents
section.
From now on, each time you open the PDF, the source files will be checked
automatically. If they have changed or if they are missing (because they have been
moved, renamed or deleted), you will see a red icon
in the Original Documents category.
For more information, refer to
Verifying the source files.
