If you do not want to use the predefined PitStop Pro shortcuts or if you want to configure some additional shortcuts, you can create your own set.
To create a shortcut set
Shortcut sets are files with extension .esc.
| Modification | Procedure |
| To modify an existing shortcut or to add a new one | 1. Select the menu command in the upper part of the pane. 2. In
the Edit Shortcut section, configure the new
shortcut:
| To delete an existing shortcut | 1. Select the menu command in the upper part of the pane. 2. Click the Delete shortcut button. |
| To restore the default Enfocus PitStop Pro shortcuts | 1. Click the Reset all shortcuts
button. The default shortcuts are shown in the list. |
Copyright ©2018 Enfocus BVBA | All rights reserved.
