Enfocus PitStop Pro provides you with a number of predefined keyboard shortcuts to access its tools.
+P on Mac.
+G on Mac. You can use these keys as they are, or you can use your own set of shortcuts.
For the complete list, refer to PitStop Pro shortcuts: overview.
If you want to use your own shortcuts, you should create a new shortcut set and "apply" it. This is also the case if you want to change only one or two shortcuts - it is not possible to change shortcuts on their own.
You can have several shortcuts sets on your system. This can be useful, if different operators use the same computer; they can each have their own shortcut set. Only one set can be applied.
All available sets are shown in the upper part of the Shortcuts pane; the currently applied set is mentioned in the lower part.
Click
or right-click a shortcut set to access the available options.
