Saving and printing a shortcut set
You can save and print a PDF file with an overview of all your PitStop Pro shortcuts. There are two lists available:
  • An overview of menu commands for which a shortcut has been defined.
  • A complete overview of all menu commands.
To save and print a shortcut set
  1. Go to Edit > Preferences (Windows OS) or Acrobat > Preferences (Mac OS) and select Enfocus PitStop Pro Preferences.
  2. In the Category field, click Shortcuts.
    In the Shortcuts pane, all available shortcut sets are shown. The shortcut set that is active is shown in the Currently applied section.
  3. Select the shortcut set you want to save and print.
  4. Click (or right-click the file) and select the appropriate option:
    • To save the complete overview of menu commands, click Save Shortcut Summary (Full List).
    • To save the list of commands for which you have defined a shortcut, click Save Shortcut Summary (Minimized List).
  5. Select a location for the file and click Save.
  6. Print the PDF file.
