Folders for reports
When a PDF document arrives in an input folder, Enfocus PitStop Serverwill run one or more Action Lists and/or a Preflight Profile. In this process, the following events may occur in the PDF document:
Detailed information about these events will be logged and summarized in preflight reports. Preflight reports are special types of PDF documents: they have hyperlinks to any potential problems, i.e. Warnings or Errors in the processed PDF documents. Thus, they help you determine why a document was labeled "Certified Not OK" or indicate specific prop­erties in successfully processed PDF documents which need special attention.
By default, preflight reports get the name of the original PDF document, with the suffix “_log.pdf”, but this can be changed using File renaming (see File renaming). You can specify dedicated folders for these reports, based on the process result of the PDF document.
