Changing the Certified PDF status of an incoming PDF document
When a PDF document arrives in an input folder of a hot folder, it can be a Certified PDF or not. You can use Enfocus PitStop Server to change the Enfocus Certified status. To this end, you set your hot folder to perform one of the following actions on the PDF document as soon as the document arrives in the input folder:
If you set your hot folder to change the Enfocus Certified status of incomingPDF documents, it will do so before it actually processes the PDF document, i.e.:
Contents
