Incoming Certified PDF documents:
If the option Make document uncertified is chosen, the PDF document will no longer be certified.
If the option Keep document status unchanged is chosen, the PDF document will remain Certified. By default, the Certified PDF document will keep its embedded Preflight Profile.
If the option Change Certified Preflight Profile to hot folder Preflight Profile is on, the Preflight Profile defined in the hot folder will be used instead of the embedded Preflight Profile.
If the option Make document Certified using hot folder Preflight Profile is chosen, the PDF document will be Certified using the Preflight Profile defined in the hot folder. However, if the option Keep original Certified Preflight Profile if incoming document is already a Certified PDF is on, the Certified PDF will keep its embedded Preflight Profile.
