There is no specific <subtitle> HTML element used; instead,
the subtitle is enclosed in paragraph tags:
<p class="introduction">Job Ticket for '%1'</p>
This paragraph is
assigned a class ("introduction"), which determines how it looks. The class is defined as follows
in the CSS
file:
form p.introduction
font-size: 1.5em;
font-weight: bold;
line-height: 1.6;
margin: 0 0 2em;
color: rgba(255,255,255,1);
/* background: linear-gradient(to right, rgba(154,169,16,1), rgba(154,169,16,0)); Esko green */
/* background: linear-gradient(to right, rgba(249,153,69,1), rgba(249,153,69,0)); Connect orange */
background: linear-gradient(to right, rgba(155,155,155,1), rgba(155,155,155,0));
box-shadow: 0px 2px 4px 0px rgba(0, 0, 0, 0.16), 0px 2px 10px 0px rgba(0, 0, 0, 0.12) !important;
padding: 6px 0 6px 10px;
The
first line (
form p.introduction) is called the CSS selector: it indicates where the CSS
code should be applied; in this example, it should be applied to a paragraph element (
p)
inside a form (
form), which is assigned the class "introduction" (
.introduction) -
the dot refers to a class.
Note: If you're using the basic Job Ticket in Connect, you can change the subtitle via the
Connect interface (HTML Layout button).
