Export metadata
Export metadata is a processor that allows saving a metadata dataset associated with the incoming job to a standalone file. The tool merely copies the dataset’s backing file to the output location without any transformations. The XSLT transform tool can be used to transform the exported metadata if needed.
The outgoing log connections carry the exported metadata; the outgoing data connections carry the incoming job without change. If the incoming job has no dataset with the specified name, no log output is generated.
Keywords
The keywords for the Export metadata element are:
Connections
Export metadata supports any number of outgoing traffic-light connections.
Properties
Property
Name
Dataset name
The name of the set of metadata (associated with the job) to be exported; see Picking up metadata for more information
Filename body
The filename for the generated metadata file (without filename extension)
Filename extension
The filename extension for the generated metadata file; select "Data Model" to automatically use "xml", "jdf" or "xmp" depending on the data model of the exported dataset (for the Opaque data model, the original backing file’s filename extension is used)
