Job dismantler is a processor that disassembles a job folder (which may have one or more levels of subfolders) into separate files.
This tool is often used to dismantle job folders that really don't represent a single job. This happens for example when a user submits a folder into the flow that contains a set of otherwise unrelated files that need to be processed individually rather than as a single entity.
Each incoming file or job folder is treated with the semantics of a submit hierarchy with regards nested subfolders and job folders.
The keywords for the Job dismantler element are:
Job dismantler injects folder filter properties into its outgoing connections so that it is possible to include/exclude certain subfolders in the incoming job folders for particular connections. Also see the "skip folders" property described below.
Name |
Subfolder levels |
The number of nested subfolder levels considered to be hot folders (as opposed to job folders); see also the description in Submit hierarchy |
Attach hierarchy info |
If set to yes, (part of) a job’s location in the job folder is added to its hierarchy location path as it is injected in the flow; see using hierarchy info for more details |
Include dismantler name |
If set to yes, the name of this flow element is included in the remembered location path |
Include job name |
If set to yes, the name of the incoming job folder is included in the remembered location path |
Include subfolder levels |
Identifies the number of hierarchy segments in the hierarchy information. |
Save top subfolders |
If set to yes, the top-most subfolders are remembered in the location path, otherwise the bottom-most subfolders are remembered |
Keep existing info |
If set to yes, the new information is added at the bottom of the existing location path; otherwise the existing location path is replaced |
Attach email info |
Email addresses and body text specified with the editor for this property are added to each job's email info as the job is injected in the flow; the information added can vary depending on the subfolder in which the job was located; see Using email info for more details |
