Mail send
Mail send is a processor (although conceptually it is a consumer) that sends an email message to an SMTP email relay server for each incoming job.
Some properties for this tool (such as the SMTP server details) are setup as a global user preference since these values are always the same for all outgoing email. Mail send will fail as long as these preferences have not been set with appropriate values for your environment.
Keywords
The keywords for the Mail send element are:
Connections
Mail send supports optional outgoing connections to provide in-flow feedback about the operation and to keep the job around without extra copying. This allows multiple send operations to be chained in an intelligent manner; for example:
Mail send supports traffic-light connections of the following types (other types are not allowed):
Properties
Property
Name
Subject
The subject line for the message.
To addresses
The list of destination email addresses for the message. Email addresses are separated by a semicolon or by a newline.
Include attached addresses
If set to yes, the email addresses from the job’s internal job ticket are added to the To addresses.
Cc addresses
A comma/semicolon separated list of carbon-copy email addresses for the message
Bcc addresses
A comma/semicolon separated list of blind carbon-copy email addresses for the message
Reply address
The email address to which a receiver of the message should send a reply. If the value is empty or Default, the reply address specified in the User Preferences is used.
Message format
The format of the message body, either Plain text or HTML. When set to HTML, an HTML message as well as a plain text version of the HTML message as an attachment will be sent.
Body template
The location of the template of the email body.
If set to Built-in, the text can be set in the Body text property. Using the Include attached body text option, you can insert the body text attached to the job as part of its email info, after the body text
If set to Fixed file, a Template file can be set, referring to a plain text or HTML file containing the template for the message body.
A plain text body template shall be a regular text file (preferred extension “.txt”) using Unicode (UTF-16 with proper BOM or UTF-8). Other text encodings are not allowed. An HTML body template shall be a valid HTML file (preferred extension “.html”) using Unicode UTF-8. The HTML file must contain a tag specifying that it uses UTF-8 encoding. Other text encodings (including UTF-16) are not allowed.
An HTML body template shall not refer to any local resources (since these will not be transmitted with the mail message). Any references should point to public resources on the worldwide web.
You can use Enfocus Switch variables in an HTML template. An example with variables you could use in your own template:
<span>Job size: [Job.ByteCount]</span>
<span>Flow name: [Switch.FlowName]</span>
<span>Current date: [Switch.Date]</span>
Also see Known variables for more information on variables.
If set to Associated with job, the name of the metadata dataset associated with the job containing a plain text or HTML template can be set.
Attach files
If set to yes, attaches the incoming file or job folder to the email message being sent
Strip unique name
If set to yes, the unique name prefix added to the filename by Switch is removed before emailing the job; the default is to strip the prefixes from jobs before emailing them
This property affects both the actual attachments and the names of the jobs listed in the email body
