Submit point is a producer that serves to submit jobs into a flow through SwitchClient by a user with the appropriate access rights. See Submitting jobs .
The backing folder for a submit point is always auto-managed.
The keywords for the Submit point element are:
Name |
The name of the flow element displayed in the canvas. By default it is displayed as "Submit point" |
Display name |
The name to be displayed in SwitchClient. If set to Default, the default name is displayed |
Thumbnail |
The image to be used as thumbnail for this Submit point in SwitchClient. Allowed image types are PNG, BMP and JPEG |
Attach hierarchy info |
If set to "Yes", part of a job's submit information (as configured with the next two properties) is added to its hierarchy location path as it is injected in the flow; see Using hierarchy info for more details |
Include Submit point name |
If set to "Yes", the name of this flow element is included at the top of the remembered location path |
Include user name |
If set to "Yes", the name of the user submitting the job is included in the remembered location path |
Attach user as email info |
If set to "Yes", the submitting user's email address is added to each job's email info as the job is injected in the flow; see Using Email info for more details |
Attach extra email info |
Email addresses and body text specified with the editor for this property are added to each job's email info as the job is injected in the flow; the information added can vary depending on the user submitting the job; see Using Email info for more details |
Enter metadata |
If set to "Yes", the SwitchClient user is asked to complete metadata fields before submitting a job; see Picking up metadata and Defining metadata fields for more information |
Metadata fields |
Definitions for the metadata fields to be entered; see Defining metadata fields for more information |
Dataset name |
A name for the set of metadata entered here; see Picking up metadata for more information |
The Submit point tool picks up metadata fields entered by the SwitchClient user when submitting a job. Specifically, when a user submits a job and the list of field definitions in the Submit point's "Metadata fields" property is nonempty, the Submit point:
Creates a metadata dataset containing the contents of the metadata fields entered by the user.
Associates this dataset with the job ticket for the submitted job under the dataset name specified in the "Dataset name" property.
Refer to Client fields schema for details on the format of the generated metadata.
