Checkpoint via mail
Checkpoint via mail is a processor that allows implementing a simple Checkpoint via e-mail, performing the following main functions:
Keywords
If you enter one of the following keywords in the Search field at the top of the Flow Elements pane, the Checkpoint via mail element will be shown in the list:
Connections
Checkpoint allows any number of outgoing move connections. The name of each connection defines a "Checkpoint action".
Properties
Property
Name
Subject
The subject line for the message.
To addresses
The list of destination e-mail addresses for the message. E-mail addresses are separated by a semicolon or by a newline.
Include attached addresses
If set to Yes, the e-mail addresses from the job's internal job ticket are added to the To addresses.
Reply address
The e-mail address to which a receiver of the message should send a reply. If the value is empty or Default, the reply address specified in the Switch preferences is used. See Switch preferences: Mail send.
Message format
The format of the message body, either Plain text or HTML.
Body template
The location of the template of the e-mail body.
If set to Built-in, the text can be set in the Body text property. Using the Include attached body text option, you can insert the body text attached to the job as part of its e-mail info, after the body text. If you set Display metadata to Yes, you can specify the Metadata fields using the Define metadata fields dialog box.
If set to Fixed file, a Template file can be set, referring to a plain text or HTML file containing the template for the message body.
If set to Associated with job, the Template dataset which is the name of the metadata dataset associated with the job containing a plain text or HTML template can be set.
Attach files
If set to Yes, the incoming job is attached to the e-mail message sent out.
Enable report viewing
If set to Yes, the metadata dataset indicated with the subordinate property is attached to the e-mail message sent out.
Report dataset name
The name of the dataset to be attached to the e-mail message.
Report name suffix
The name of the attached report is formed by adding this suffix to the name of the job, before the file name extension.
Report name extension
The file name extension for the report. Select "Data Model" to automatically use xml, jdf or xmp depending on the data model of the exported data set. For the Opaque data model, the original backing file's extension is used.
Allow multiple outputs
If set to Yes, the user can send copies of a job along more than one outgoing connection; otherwise the job is sent along exactly one of the outgoing connections.
Server type
The type of server from which to retrieve email. Choices are POP3 and IMAP.
Server address
The URL or IP address of the server from which to retrieve e-mail.
Port Specify the port to be used for communication with the server.
Accounts
A list of accounts (names and corresponding passwords) from which to retrieve e-mail.
Use secure password verification
Defines whether to log in to the e-mail server using secure password verification.
Server requires secure connection (SSL)
Defines whether the e-mail server requires a secure connection using the SSL protocol.
Check every (minutes) The frequency of checking the e-mail accounts for new messages.
Fail jobs after timeout
If set to Yes, jobs are failed after residing in the Checkpoint for a certain period of time (specified in the subordinate properties).
Failed jobs are moved to the outgoing connection specified in the subordinate properties or to the problem jobs folder.
Unit Selects the unit for the subsequent property: Minutes, Hours, Days.
Timeout delay The timeout delay in the units indicated by the previous property (0 means ‘no timeout').
Fail connection
The name of the connection to which failed jobs must be moved.
If this property value is empty or if the specified name does not match any of the outgoing connection names, failed jobs are moved to the problem jobs folder.
Reply syntax
The user's reply message must specify the job ID and the selected Checkpoint action(s) in a simple format. Specifically, Switch searches for the following character sequences:
In both cases, the text is case insensitive. All other text in the message is ignored.
Examples
Mail sent to user
Job identifier: 0044P
Message text:
Body text........
...........end.
Possible Checkpoint actions (please choose any):
Accept
Reject
Email was triggered by this file :
Test.txt Attachments:
Job file: Test.txt
--- Important information ---
Reply message should contain the following lines:
Action: action from the list above or comma separated actions list
Reply from user
Action: Accept
