These preferences allow you to configure the way (log) messages are handled in Switch.
For more information about the different message types, refer to Message types.
Saving log messages |
Determines the mechanism for saving log messages to the Switch logging database:
Export messages to XML |
When set to Yes the messages stored in the execution log are automatically exported to XML files at a time and interval as configured by the user (see below), starting with the day on which the feature was turned on. Note:
The name of the exported files include the Switch server name (as set in the Internal communication preferences) and the date. The file name format is "<server-name> logs YYYY-MM-DD.xml". Example: SwitchServer logs 2013-12-25.xml For information on the XML schema of the exported files, see XML schema. If Export messages is set to
Yes, the following additional fields
appear:
Log to CSV file |
If set to Yes, all execution log messages are written to a CSV file in addition to the regular log database. A new log file is created every 10.000 messages and every day. The name of the log file includes the date and the time (YYYYMM-DDHHmmss). Note: Enable this option only on request of the Enfocus
technical support team.
The following options are only available if Log to CSV file is set to Yes. |
CSV file delimiter The delimiter separating the records in the generated CSV log file, for example a comma or a semicolon. |
Log files folder Folder where the CSV log files will be stored. If set to Default, the log files are stored in the "Logs" folder of the Application data root (see Switch preferences: Application data). |
Log debug messages If set to Yes, assert and debug messages are also written to the log file. If set to No, the assert and debug messages are just discarded. Note: Assert and debug messages are never shown in the Messages
pane!
Refer to Columns. |
| Log FTP interaction | If set to Yes, problems with failed
FTP transfers are logged and saved in:
The following option is only available if Log FTP interaction is set to Yes. |
Clean the log when flow is activated If set to Yes, the FTP interaction logs will be deleted when the flow is activated.Note: When logs are stored for a long time, Switch may become
slow and sometimes non-responsive. Therefore, we recommend
clearing logs regularly.
