The Database module is an advanced module that allows
read/write access to databases
(through ODBC data sources) without the need for extensive scripting. With the database
module, business or job management software can be used in conjunction with Switch workflows
to further automate job decisions.
An active Database module license provides you with
access to:
- Database values when defining metadata for a Submit point in SwitchClient or a Connector in Connect
ALL (see the Connect documentation on the Enfocus website).
