Rename job
Rename job is a processor that provides various mechanisms for renaming the incoming job and/or the files inside a job folder.
Keywords
The keywords for the Rename job element are:
Connections
Rename job allows only a single outgoing connection.
Properties
Property
Name
Affect job name for
Determines for which jobs the rename actions are applied to the name of the job (individual file or job folder):
  • All jobs
  • Individual files only
  • Job folders only
  • No jobs
Remember original name
If set to yes, the original filename of the incoming job is stored in private data in the internal job ticket for the job so that it can be restored with a subsequent rename flow element; see Restoring the original filename
Only the name of the job is remembered; not the name of any files inside a job folder
Private data key
The first portion of the private data key used to store the original filename; see Restoring the original filename
Files inside job folder
Determines what to do with files inside a job folder:
  • Leave alone
  • Rename files
  • Rename files and folders
  • Flatten hierarchy (discarding folders)
  • Flatten hierarchy and rename files
Nested folder levels
Specifies the number of nested subfolder levels to act on (zero means "leave alone"; use a large number to act on all levels)
Resolve collisions
Determines how to resolve situations where two files on the same level end up with the same name (after all other actions specified in this tool have been performed):
  • Add suffix after filename proper (= filename without extension)
  • Add suffix after complete filename
  • Modify name without changing length
Pattern
A pattern for the suffix or replacement string used to resolve collisions; "count" is replaced by a number with an appropriate number of digits (that is, a single digit unless there are many files colliding to the same name)
Action 1
Determines the first rename action taken:
  • None
  • Add prefix
  • Add suffix
  • Remove segment
  • Keep segment
  • Replace
  • Search and replace
  • Reduce character set
  • Remove extension
  • Add extension
  • Replace extension
Act on
Determines which portion of the filename is affected:
  • Filename proper (= filename without extension)
  • Complete filename (select this if the file has no extension)
Prefix
The prefix to add at the start of the filename
Suffix
The suffix to add at the end of the filename
Start index
The one-based start index of the filename segment to remove/keep
End index
The one-based end index of the filename segment to remove/keep; zero means until the end of the filename
Search for
The search string to be replaced, or a regular expression that matches the string to be replaced
Replace by
The replacement string, or a regular expression that can use the groups captured by the search regexp
Repeat
Determines the repeat behavior of the search/replace:
  • Once: only the first match is replaced
  • Consecutive: repeated as many times as needed to reach the end of the filename (however the replaced portion is NOT searched again)
  • Recursive: consecutive is repeated until the filename no longer changes (with a max. of 99 iterations)
Allowed character set
Determines the allowed character set:
  • Local8bit: the current ANSI code page on Windows (Latin1 on Western systems); UTF-8 (i.e. anything) on Mac OS X
  • Portable ASCII: printable 7-bit ASCII less those characters that aren't allowed in filenames on some systems
Replacement character
Determines the replacement for disallowed characters:
  • Underscore
  • Space
  • Remove
New extension
The new filename extension
Action 2 … Action 5
The subsequent rename actions taken; these properties have the same subordinate properties as the first action property
If the "Remember original name" property is set to yes, the tool stores the original name of the incoming job in the internal job ticket for the job using private data keys as follows:
Private data key
Stored value
<key>
The original filename including extension
<key>.Name
<key>.NameProper
The original filename without extension
<key>.Extension
The original filename extension
For example, if the private data key property is left to its default value, the original filename without extension can be retrieved later on with the following variable:
[Job.PrivateData:Key="Original.NameProper"]
The "Remember original name" option works even if all rename actions are set to "none"; this can be useful to capture the job name before it gets changed by some other tool or application.
