| Configurator | Remarks/Extra documentation |
| AccuZIP | |
| Adobe Acrobat Distiller | Scripted plug-in as of Switch 13* |
| Adobe Acrobat Professional | Scripted plug-in as of Switch 13* |
| Adobe Illustrator | Scripted plug-in as of Switch 13* |
| Adobe InDesign | Scripted plug-in as of Switch 13* |
| Adobe InDesign Server | Scripted plug-in as of Switch 13* |
| Adobe Photoshop | Scripted plug-in as of Switch 13* |
| Alwan ColorHub | |
| Apago PDF Enhancer | |
| Apago PDFspy | |
| Apple Automator | |
| Aproove | |
| Automation Engine | Extra documentation (system requirements and troubleshooting) for the Automation Engine Configurator is available at: http://www.enfocus.com/manuals/Extra/Switch/SwitchAutomationEngineConfigurator.pdf |
| Axaio MadeToPrint InDesign | |
| Axaio MadeToPrint InDesign Server | |
| Axaio MadeToPrint Illustrator | |
| Axaio MadeToPrint QuarkXPress | |
| Caldera Nexio Collect | New in Switch 13 |
| Caldera Nexio Submit | New in Switch 13 |
| callas PDFaPilot | |
| callas pdfToolbox Server | |
| callas pdfaPilot | |
| callas Toolbox Actions | |
| callas Toolbox Compare | |
| callas Toolbox ConvertColors | |
| callas Toolbox Impose | |
| callas Toolbox Profiles | |
| CHILI Publisher | |
| ColorLogic ProfileTagger | |
| ColorLogic ZePrA | |
| Convert to Twixl Web Reader | |
| CorelDRAW | As of Switch 13, compatible with CorelDRAW X7. Note: The Fail jobs
with unavailable images option must be set to
Yes, if you're using CorelDRAW X7; this option can only
be turned off if you're using an older version of CorelDRAW.
| Dynagram InpO2 | |
| EFI Fiery XF | |
| Elpical Claro | |
| Elpical Claro Premedia Server | |
| Enfocus PitStop Server | |
| Enfocus PitStop Server PDF2Image | New in Switch 13. Note: This configurator is installed and updated with
PitStop Server. If you're using PitStop Server 13 update 1, the configurator is
able to handle Switch metadata attached to the PDFs you're converting
| GlobalVision Inc Barproof | Windows only |
| HP SmartStream Designer Ganging | |
| HP SmartStream Designer Impositon | |
| HP SmartStream Designer VDP | |
| HP SmartStream Production Center JDF Control | |
| HP Digital Front End JDF Controler | |
| Imaging Solutions VIESUS | |
| Made ToPrint Illustrator | |
| Made ToPrint InDesign | |
| Made ToPrint InDesign Server | |
| Made ToPrint QuarkXPress | |
| Microsoft Excel | |
| Microsoft PowerPoint | |
| Microsoft Word | Separate versions for Mac OS and Windows |
| Phoenix Plan | |
| QuarkXPress (Mac only) | Support for QuarkXPress 2015 (Switch 13) |
| Quite Hot Imposing | |
| Saxonica Saxon | New in Switch 13 |
| StuffIt Deluxe | |
| Ultimate Impostrip On Demand | |
| Upload to Twixl Distribution Platform | |
| WoodWing Enterprise Download | |
| WoodWing Enterprise Upload |
* The Adobe configurators are now scripted plug-ins instead of C++ applications integrated in Switch. As a consequence, new versions of these configurators can be downloaded from the the Enfocus website (Switch Partner integrations overview/Adobe) or from within Switch, through PackManager, just like any other configurator. They are no longer tied to Switch releases.
