A number of configurators are installed by default, together with Switch, but you can afterwards install additional configurators as required.
To install a configurator from within Switch
This could be configurator you downloaded from the Enfocus website (Partner integrations overview), or one you created yourself in SwitchScripter with the Configurator SDK.
) at the right
hand side indicates that the 3rd party application is installed; a gray icon
) indicates that this is not the case, hence the
installed configurator cannot be used in Switch.
). Ater
restarting Switch (both Server and Designer), you will see the configurator in
the Flow elements name (in the Configurator category).
