This tool helps in configuring certain settings in the databases (like selecting Datasource, adding SQL statement etc) without the use of scripting. It is only available if you have licensed the Database module.
Drag and drop the Database Connect to the workspace.
Name |
Provide a name for the flow element. This name is displayed in the workspace. |
Select data source |
Select a data source from the list of predefined data sources.
Note: If
the list is empty, you should first set up a data source. Refer to the ODBC
data sources option in the User preferences dialog
(See Setting up an ODBC database connection).
SQL statement |
Specify SQL statements using any one of the
following three options:
Note: Please pay special attention when using other variables and make sure that the result
of the multi-line text is a valid SQL statement.
| Log name | Specify the name of the log where the result of the statement should be written by
using one of the following three options:
| Binary data in opaque dataset | If the result of the SELECT statement returns binary data (for example: video form), select Yes. Otherwise, select No and configure the subordinate properties. |
| Log type | Only available if Binary data in opaque dataset is set to No. Format of the log (where the result of the statement will be written). Options:
| Encode binary data | Only available if Binary data in opaque dataset is set to No. Defines the way binary data is converted.
At present there is no SQL editor available. Therefore, copying statements generated by the variables, multi line text with variables, database group and build SQL statement dialog box may result in errors.
