Switch allows you to collect information on how long jobs reside in certain folders or states while being moved along a flow. This can be useful to identify performance bottlenecks.
Statistics are not limited to a single flow: Switch combines all statistics-enabled folders from all active flows in a single set of statistics. If two or more folders (used in different flows) have the same name, the statistics for these folders are combined in one single entry.
You can only gather statistics for a folder that has outgoing connections. Folders at the end of the flow do not have the Show in statistics and Attach job state property, because Switch has no control over the time the jobs reside in such a folder.
Remark
To display the Statistics pane, click
in the Switch toolbar or go to .
You can display up to three statistics panes (by clicking or Statistics 3) at the same time. This allows you to display a second and third set of statistics (e.g. sorted in a different way).
For more information about this pane, refer to Statistics pane.
To remove the collected information, i.e. to set all counters to zero, go to . Switch will start gathering statistics from scratch.
