Variable data type |
Comparison operators |
Comparison value |
Text |
Equal to Not equal to Contains Does not contain Starts with Does not start with |
Any text string |
Matches Does not match |
A regular expression |
Boolean |
True False |
None |
Integer Rational |
Equal to Not equal to Less than Less than or equal Greater than Greater than or equal |
A decimal integer or floating point number, example, "-12" or "0.56" A constant expression using + - * / operators; example:
Date |
Equal to Not equal to Earlier than Earlier than or same Later than Later than or same |
An ISO 8601 formatted date/time (equivalent to format string "yyyy-MM-ddThh:mm:ss.zzz") or any portion thereof Enter a format string in the Format argument of the variable to specify which portion of the date and/or time should take part in the comparison For example, you may enter "yyyy-MM" for the format string and "2007-08" as the comparison value to compare year and month |
