The following properties are displayed in the Properties pane, when you select a particular flow.
Name |
The name of the flow as it is shown in the Flows pane. |
A description of, or comments about the flow; the text in this field may have multiple lines. The creation date and time are filled in automatically (but can be removed as required). |
Background image |
A PNG or JPG image to be shown in the
background of the flow design.
The background image is a kind of wallpaper on which the flow design is drawn. Light colors or sober patterns work best. |
Header image |
A PNG or JPG image to be shown in the upper-left corner of the flow design, on top of the background image.
The header image is intended to mark a flow with a company or brand logo. Small images work best (avoiding overlap with the actual flow design). |
Allow advanced performance tuning |
Performance settings are configured in the Switch Preferences (Switch preferences: Processing). They apply to all flows and all flow elements. However, to improve the performance of a particular flow, you
can overrule two default settings by enabling the
Allowing advanced performance
tuning option in the properties of that
flow. As a result, all flow elements (used in that
particular flow) that can process jobs concurrently, will
have two additional properties that can be changed:
| Time-of-day window | If set to
Yes, the flow will be active during a
particular time of the day, as specified in the following
properties (only available if Time-of-day window is
enabled):
| Day-of-week window | If set to
couple of days of the week, as specified in the following
properties (only available if Day-of-week window is
enabled):
| Day-of-month window | If set to
particular day of the month, as specified in the following
properties (only available if Day-of-month window is
enabled):
. This
indicates that the flow is scheduled and will be active during the time
specified in the Flow properties.
