Switch Server name |
The name of this instance of the Switch Server. This name will be shown in the legacy version of SwitchClient. It is also used in the title bar of the application and in the file name of exported logs. Note: Changing the server name requires a restart of
Switch.
Port for Switch Designer |
The port used for communication between Switch Server and Switch Designer, in the range of 1 to 65535. |
Port for Watchdog - Switch Server |
The port used for communication between Switch Server and Switch Watchdog, in the range of 1 to 65535. |
Port for Watchdog |
The port used for communication between Switch Designer and Switch Watchdog, in the range of 1 to 65535. |
| Job client type |
Type of client used to submit and check jobs:
Note:
The following options are only available if Job client type = legacy. |
| Compress SwitchClient jobs |
| Port for SwitchClient |
Port to be used for the communication between Switch Server and SwitchClient instances. |
