Job dismantler
Job dismantler is a processor that disassembles a job folder (which may have one or more levels of subfolders) into separate files.
This tool is often used to dismantle job folders that really do not represent a single job. This happens for example when a user submits a folder into the flow that contains a set of otherwise unrelated files that need to be processed individually rather than as a single entity.
Each incoming file or job folder is treated with the semantics of a submit hierarchy with regards nested subfolders and job folders.
Keywords
The keywords for the Job dismantler element are:
Connections
Job dismantler injects folder filter properties into its outgoing connections so that it is possible to include/exclude certain subfolders in the incoming job folders for particular connections. Also see the "skip folders" property described below.
Properties
Property
Name
Subfolder levels
The number of nested subfolder levels considered to be hot folders (as opposed to job folders); see also the description in Submit hierarchy
Attach hierarchy info
If set to yes, (part of) a job's location in the job folder is added to its hierarchy location path as it is injected in the flow; see using hierarchy info for more details
Add dismantler name
If set to yes, the name of this flow element is included in the remembered location path
Add job folder name
If set to yes, the name of the incoming job folder is included in the remembered location path
Include subfolder levels
Identifies the number of hierarchy segments in the hierarchy information.
Save top subfolders
If set to yes, the top-most subfolders are remembered in the location path, otherwise the bottom-most subfolders are remembered
Keep existing info
If set to yes, the new information is added at the bottom of the existing location path; otherwise the existing location path is replaced
Attach email info
Email addresses and body text specified with the editor for this property are added to each job's email info as the job is injected in the flow; the information added can vary depending on the subfolder in which the job was located; see Using email info in Switch for more details
