Recycle bin
Recycle bin is a consumer that deletes incoming jobs either immediately or depending on the jobs size, age etc...
Keywords
The keywords for the Recycle bin element are:
Connections
Recycle bin does not allow outgoing connections.
Properties
Property
Name
Path
The path of the Recycle bin's backing folder on disk, or "auto-managed". For more information on "user-managed" versus "auto-managed" folders, refer to Folder.
Keep N jobs
If set to zero, jobs are deleted immediately when they arrive in the Recycle bin (unless another Keep ... jobs property applies).
If non-zero, the Recycle bin only deletes the jobs when the total number of jobs in the Recycle bin exceeds the given limit (N); the oldest jobs are then deleted until the number of jobs in the Recycle bin is once again under the limit.
Note: The different "Keep...jobs" properties of the Recycle bin tool are independent; jobs are deleted as soon as they exceed the limit of any of the "Keep ... jobs" properties.
Keep N MB jobs
If non-zero, the Recycle bin only deletes the jobs when the total size of all jobs in the Recycle bin exceeds the given limit (N); the oldest jobs are then deleted until the total size of the jobs in the Recycle bin is once again under the limit.
Keep jobs for N (hours)
If non-zero, the Recycle bin only deletes the job after a specific number (N) of hours; any job that is older than the limit is permanently removed from the Recycle bin.
Move to system recycle bin
If set to No (default), jobs moved to the Recycle bin are deleted permanently.
If set to Yes, jobs deleted by the Recycle bin tool are not permanently deleted but instead moved to the system Recycle bin, so they can be recovered if they were deleted by accident. Note that you need to empty the bin regularly, otherwise you'll run out of disk space.
Strip unique name
Only available if Move to system recycle bin is set to Yes.
If set to Yes, the unique name prefix added to the filename by Switch is removed before moving the job to the system Recycle bin.
