Folder is a central flow element that serves as an intermediary for moving jobs between other flow elements. Each folder flow element instance represents a backing folder on disk that can hold jobs before, after or in between processing steps. The contents of the backing folder can also be accessed by external processes or by users. For example, a folder may be used to submit jobs into a flow or to retrieve the results of a flow.
If you enter one of the following keywords in the Search field at the top of the Flow elements pane, the Folder element will be shown in the list:
Any subfolders placed into a folder are treated as a job folder; that is, the subfolder and its contents are moved along as a single entity.
If a folder has no outgoing connections (that is, it is a "dead-end" folder), a job placed in the folder will stay there until it is removed by some external process that is not under the control of Switch.
If a folder has at least one outgoing connection, a job placed in the folder is removed after it was processed by all outgoing connections. If none of the filters on the outgoing connection(s) match, the job is moved to the problem jobs folder. Refer to Handling problem jobs and error handling preferences for more details.
| Auto-managed | User-managed | |
| Location on disk | Special area managed by Switch, i.e. "the application data root" (see Switch preferences: Application data) | Location selected by the user (through the Path property) |
| Editable by the user? | No, users should not manipulate auto-managed
folders! Note: The Open in
Explorer/Finder option in the context menu
is only available if you hold down Shift while
right-clicking the folder on the canvas. This is an advanced
preference that only should be used for debugging
purposes!
Yes, through the Open in Explorer/Finder option in the context menu. |
| Scanned? | No need to scan, as the contents is known and managed by Switch. | Yes, at regular intervals as defined in the Preferences (See Switch preferences: Processing) |
| Lock icon? | Yes![]() |
No![]() |
| Remarks | External processes (not under control of Switch) and users should not refer to auto-managed folders since they can change the name and/or location under the control of Switch! | It is not allowed to point user folders to auto-managed folders (e.g. containing the result of another flow). As auto-managed folders are not scanned, this will not work. |
For more information on how to create an auto-managed or user-managed folder (or to switch from one type to the other), refer to Using Folder elements in Switch.
Note that certain properties are present only for folders that have at least one outgoing connection, and certain other properties are present only for folders that have no outgoing connections ("dead-end" folders)
Name |
The name of the folder displayed in the canvas. A newly created folder receives a default name ("Folder 1", "Folder 2", ...), which you should replace with a meaningful name. Note: If you set up a user-managed backing folder while a
"Folder <number>" name is still in place, the flow
element automatically adopts the name of the backing folder.
For example, if you drag "D:\data\input" onto the canvas,
the folder will be named "input".
A description of the folder displayed in the canvas. This description is also shown in the tooltip that appears when moving your cursor over the folder. |
Path |
The path of the folder's backing folder on disk, or auto-managed. The following options in italics relate to the frequency of which the folders are scanned for new files. As auto-managed folders are not scanned, these options are only available for user-managed folders. |
Leave originals in place |
If set to Yes, incoming jobs are left untouched in the folder. Switch never writes to the folder, so read-only access rights suffice; see Leaving originals in place. If set to No (default), incoming jobs are moved out of the folder; Switch needs full access rights to rename, create and remove files and folders. Ignore updates (only available if if Leave originals in place is set to Yes) If set to Yes, a job will only be processed once, regardless of any changes to the file size or modification date. This can be used for workflows where the input job is replaced by the processing result, to avoid triggering endless loops. If set to No, the job will be reprocessed when its file size or modification date is different. This allows processing jobs which have the same file name as previously submitted jobs. |
Minimum file size (KB) |
Used to set the minimum file size limit (in KB) before Switch picks up the files or folders. To set no limits, leave it empty. |
Scan every (seconds) |
The frequency with which this folder is scanned for newly arrived jobs. If set to Default or zero, the global user preference is used instead; see Switch preferences: Processing. |
Time-of-day window |
If set to Yes, the folder detects (and moves) newly arrived jobs only during a certain time of the day (specified in the subordinate properties). Allow from (hh:mm) and Allow to (hh:mm) The time-of-day window during which to detect jobs. The values are structured as "hh:mm" (hours, minutes) indicating a time of day on a 24 hour clock; an empty value means midnight; two identical values mean the folder always detects jobs. |
Day-of-week window |
If set to Yes, the folder detects (and moves) newly arrived jobs only during certain days of the week (specified in the subordinate properties). Allow from and Allow to The days of the week (Monday, Tuesday, Wednesday, Thursday, Friday, Saturday, Sunday) during which to detect jobs. Two identical values mean the folder only detects jobs on that specific day. |
Day-of-month window |
If set to Yes, the folder detects (and moves) newly arrived jobs only during a certain day of the month (specified in the subordinate properties). Day The day in the month during which to detect jobs, as a number in the range [1 . .31]; the default value of one means the first or the last day of the month (depending on the following property). Relative to Determines whether the day of the month is relative to "Start of the month" or "End of the month". |
Color |
The color of the folder displayed in the canvas. The default is Yellow, but you can select another color from the list (Orange, Green, Cyan, Blue, Magenta). Alternatively, you can change the color via the context menu, by selecting the Choose color option. Refer to Adjusting the colors of folders and connections. |
Attach hierarchy info |
If set to Yes, the folder's name is added to each job's hierarchy location path as the job passes through the folder; see Using hierarchy info. Add name at the top If set to Yes, the folder name is added at the top of the hierarchy location path; otherwise it is added at the bottom. |
Attach email addresses |
The specified email addresses are added to each job's email info as the job passes through the folder; see Using email info in Switch. |
Attach email body text |
The specified email body text is added to each job's email info as the job passes through the folder; see Using email info in Switch. |
Attach job state |
If the specified string is non-empty, the job state of each job is set to the string as soon as the job arrives in the folder; the statistics view can display the average time spent for each job state. For more information, see Viewing statistics. |
Set job priority |
| Safe move | This option is only available for output folders and relevant for transferring job files between folders on different volumes (drives/partitions). If set to Yes (default value), Switch will first copy the job to a temporary file before deleting the job from the original location. This is useful to avoid that files get lost in case of network problems.If set to No, Switch immediately moves the job files to the output folder. This may be necessary in case of network permission issues. |
Strip unique name |
If set to Yes, the unique name prefix added to the filename by Switch is removed before placing the job in the folder. the default is to strip the prefixes from jobs deposited in a dead-end folder - leaving the prefixes in place avoids overwriting a previously deposited job with the same name. Duplicates Determines what happens when Strip unique
name is set to Yes
and a job arrives with the same name as a job already
residing in the folder:
Ignore these subfolders |
All subfolders that match the specified folder filter are ignored for the purpose of counting the number of jobs residing in this folder. This property appears only when the folder's outgoing connection leads to a generic application; if that application stores information in subfolders inside its input folder, this property allows Switch to ignore these folders and their contents. |
Show in statistics |
Set to Yes, if the average time that jobs reside in this folder should be calculated and displayed in the Statistics pane. For more information, see Viewing statistics. |
