These preferences configure the settings related to the communication between Switch and its client applications.
| Property | Description |
| Port for the Switch Web Service |
The port used for communication between the Switch Web Service and a client application, in the range of 1 to 65535. Default value: 51088 |
| Port for the Switch Web Portal |
The port used for communication between the SwitchClient WebServer and a client application, in the range of 1 to 65535. Default value: 51089 |
| Protocol | The protocol used for the communication between the Switch WebServer and the
browser. Choices:
Note: If your browser does not recognize the used certificate, it will block the
Log messages overview. In that case, you must add it as an exception in your
browser settings.
| Privacy policy page | URL (starting with "http" or "https") of the privacy policy of your company.
This URL is used to make the privacy policy of your company available to users of
the Switch Web Portal. Example URL: http://www.enfocus.com/en/privacy-policy/ If this property is empty, no privacy policy is displayed. Note: Changing this property requires a restart of Switch.
A privacy policy contains the guidelines a company uses to protect the information provided by its customers. It's a legal requirement to have such a privacy policy if you're collecting data from your customers. As in Switch the language preference of the users is stored (using cookies) when they launch messages in a web browser, we recommend entering the link to your privacy policy. The privacy policy is made available as follows:
