Configurator overview
Configurator Remarks/Extra documentation
AccuZIP
Adobe Acrobat Distiller Scripted plug-in as of Switch 13*
Adobe Acrobat Professional Scripted plug-in as of Switch 13*
Adobe Illustrator Scripted plug-in as of Switch 13*, updated in Switch 2017
Adobe InDesign Scripted plug-in as of Switch 13*, updated in Switch 2017
Adobe InDesign Server Scripted plug-in as of Switch 13*
Adobe Photoshop Scripted plug-in as of Switch 13*, updated in Switch 2017
Alwan ColorHub
Apago PDF Enhancer
Apago PDFspy
Apple Automator Scripted plug-in as of Switch 2017 update 1*
Aproove
Automation Engine Extra documentation (system requirements and troubleshooting) for the Automation Engine Configurator is available at: http://www.enfocus.com/manuals/Extra/Switch/SwitchAutomationEngineConfigurator.pdf
Axaio MadeToPrint InDesign
Axaio MadeToPrint InDesign Server
Axaio MadeToPrint Illustrator
Axaio MadeToPrint QuarkXPress
Caldera Nexio Collect Available since Switch 13
Caldera Nexio Submit Available since Switch 13
callas PDFaPilot
callas pdfToolbox Server
callas pdfaPilot
callas Toolbox Actions
callas Toolbox Compare
callas Toolbox ConvertColors
callas Toolbox Impose
callas Toolbox Profiles
CHILI Publisher
ColorLogic ProfileTagger
ColorLogic ZePrA
Convert to Twixl Web Reader
CorelDRAW As of Switch 13, compatible with CorelDRAW X7
Note: The Fail jobs with unavailable images option must be set to Yes, if you're using CorelDRAW X7; this option can only be turned off if you're using an older version of CorelDRAW.
DesignMerge Pro New in Switch 2017 update 1
Dynagram InpO2
EFI Fiery XF
Elpical Claro
Elpical Claro Premedia Server
Enfocus PitStop Server
Enfocus PitStop Server PDF2Image Available since Switch 13
Note: This configurator is installed and updated with PitStop Server. If you're using PitStop Server 13 update 1 or later, the configurator is able to handle Switch metadata attached to the PDFs you're converting!
Firstlogic DQ-U.S. New in Switch 2017
GlobalVision Inc Barproof Windows only
GMG ColorServer New in Switch 2017 update 1
Harlequine RIP New in Switch 2017 update 1
HP SmartStream Designer Ganging
HP SmartStream Designer Impositon
HP SmartStream Designer VDP
HP SmartStream Production Center JDF Control
HP Digital Front End JDF Controler
Imaging Solutions VIESUS
Made ToPrint Illustrator
Made ToPrint InDesign
Made ToPrint InDesign Server
Made ToPrint QuarkXPress
Microsoft Excel
Microsoft PowerPoint
Microsoft Word Separate versions for Mac OS and Windows
Phoenix Plan
QuarkXPress (Mac only) Support for QuarkXPress 2015 (Switch 13)
Quite Hot Imposing
Saxonica Saxon Available since Switch 13
StuffIt Deluxe
Ultimate Impostrip On Demand
Upload to Twixl Distribution Platform
WoodWing Enterprise Download
WoodWing Enterprise Upload
* As of Switch 2017, the old versions of the Adobe configurators (C++ applications) are no longer supported. The new scripted plug-ins are compatible with Adobe CC 2015 (and later) and Adobe Acrobat DC.
