Workspaces
A workspace allows you to customize PitStop Pro’s user interface (for example by showing or hiding Enfocus panels), so you can see as much or as little of it as you want.
Workspaces also include other settings from Adobe Acrobat and Enfocus PitStop Pro, like windows’ positions, view and color settings, Design Layouts, etc.
You can use the default workspaces provided with PitStop Pro, or create workspaces adapted to the different tasks you perform with PitStop Pro. You can also quickly switch between workspaces as needed, or set a startup workspace. For example, if you always want to see the page boxes, when working with PDF documents, you can configure a workspace with the page boxes enabled and set this workspace as your default one.
