Changing flow properties
To view the properties of a flow, select the flow in the flows pane and make sure that none of the flow elements in the canvas are selected. This ensures that the properties pane displays the flow's properties (rather than the flow element's properties)
You can now change the flow's properties by editing the values in the properties pane; see Working with properties.
Renaming a flow
You can also change a flow's name by clicking on the name field in the flows pane after the flow was already selected, and then typing the new name.
Choosing images
You can also change the background and header image by choosing the corresponding menu item in the canvas context menu.
Allowing advanced performance tuning (PowerSwitch only)
You can unlock 2 properties on flow elements that are able to process jobs concurrently.
When set to Yes, you will be able to change the default number of slots and the idle time-out for those elements. See "Default number of slots for concurrent processing" in Processing
