Editing or creating a Preflight Profile
To edit or create a Preflight Profile
  1. Open the Preflight Profiles dialog box. See To open the Preflight Profiles dialog box.
  2. Create a new Preflight Profile or edit an existing one:
    • To create a new Preflight Profile based on an existing one, click > New > New From/New from File and select the Preflight Profile you want to start from.
      The option New from allows you to select an existing Preflight Profile from the Standard database; New from file allows you to select a file (*.ppp) from your computer.
    • To create a new Preflight Profile from scratch, click > New > New .
    • To edit an existing Preflight Profile, double-click it. Alternatively, you can select the preferred Preflight Profile and click > Edit .
    If the Preflight Profile is fully locked, you will be asked to enter a password before you can see the content of the Preflight Profile.
    If it is partially locked, you will be able to view the content of the Preflight Profile, but you'll have to click the Lock icon and enter the password, before you can make any changes. Refer to Locking a Preflight Profile with a password.
  3. In the SETUP > General category
    1. Check and, if necessary, change the Profile Properties: Name, Author, and Company.
    2. Check and, if necessary, change the Description of the Preflight Profile.
    3. In the Permissions section, you can choose to (partially) lock the Preflight Profile to prevent users from changing the Preflight Profile. See Locking a Preflight Profile with a password.
    4. In the Problem Handling section, you can decide what you want to do when an error occurs.
      • Allow fixes: If enabled, PitStop will try to solve any problems. If disabled, problems will be logged but not resolved.
      • Allow sign-off: If enabled, the user will get the chance to sign off on problems for which the Sign-off flag is set (see step 5d). This allows the user to treat errors as warnings if they are considered less severe. See Sign-off. If disabled, users cannot sign off errors, even if the Sign-off flag is set.
      • Log fixes: If enabled, all fixes made in the PDF are listed in the Preflight Report.
    5. In the Preflight Report section, along with the preflight details you can choose to include information about fonts, color, page boxes, inks, images, OPI, and output intent.
  4. In the SETUP > Color Management category, enable color management as required.
    See Defining the color management settings of a Preflight Profile.
    Color management allows you to define which ICC profiles are used whenever color conversions are made during preflight and correction. This is useful to minimize color differences between devices. If you don't enable color management, the generic color conversion from your operating system will be used.
  5. In the CHECK ON category, indicate which problems should be detected (and optionally be fixed).
    1. Select the checkbox next to the profile checks you want to enable, for example "PDF Standards", "Document", "Page", ...
    2. In the Available Checks section (right panel), double-click the checks or potential problems you want to add to your Preflight Profile. For more information about a check, hover your cursor over it. A tooltip with additional information will appear.
      Note: To remove a check from the Profile, click the Actions menu and select Delete this problem.
    3. Under Problems to detect, set any attributes or values as required. Depending on the check, you may have to choose a version number or enter a value, ...
      Note: Instead of fixed values, you can also use variables (special, well-recognizable text strings that get replaced by a dynamic value), by clicking the Actions menu and selecting Enable Variable Names. Refer to the chapter about Smart Preflight and Preferences > Enfocus PitStop Pro Preferences > Variable Sets.
    4. Select how the detected problem should be listed in the preflight report:
      • Warning : Warnings are no real problems, but you may want to be informed about them. In a Certified PDF workflow, warnings are not blocking.
      • Sign-off : If a problem is set to Sign-off , the user can decide to handle the problem as a warning and sign off on it, thus allowing the PDF to pass preflight.
      • Error: Errors are considered severe problems. In a Certified PDF workflow, they block the PDF from being certified OK.
    5. Specify how to fix the problem, if necessary. You may want to just log the problems and not fix them yet. Also, if you want to decide which instances to fix, you may just log the problem and fix the problems using the Enfocus Navigator.
    6. Repeate the previous steps for each problem you want to check and/or fix.
  6. In the EXTRA category, add one or more Action Lists to the Preflight Profile as required. See Adding Action Lists to a Preflight Profile.
    This is useful if you want to make changes to the PDF (e.g. correcting colors) before performing the preflight check, or if you want to run Check Actions after the preflight check. If included in the Preflight Profile, all checks and changes can be made in one go.
  7. Click OK.
