The Smart Preflight variables for use in Preflight Profiles must be defined before you can use them. This topic explains how you can create and define new variables.
To define Smart Preflight variables
| Field | Meaning |
| Name | Choose a meaningful name, for example, the check the
variable is intended for. This name will be visible in the Preflight Profile editor or in the Action List editor, when applying a variable to a check or fix (see Applying variables to a check in a Preflight Profile). For this reason, it is advisable to keep this name as short as possible. |
| User Readable Name | Use this field if the variable name is too technical
or too short to be clear enough. It will be shown (if defined) in the Smart Preflight dialog that appears when running a Smart Preflight check in PitStop Pro (see Running a Smart Preflight check). |
| Type (First list) |
Choose the appropriate type. Refer to Smart Preflight Variables: types. |
| Type (Second list) | The type of the values produced by this variable. For
example, if a variable for a trim page size is to be
created, then it must have a "Length" variable type. If
a variable is needed to select or deselect a check box
(such as to turn on a correction), then a Boolean
variable type needs to be defined. Some examples for
each option:
| Type (Third list) | In case of a Job Ticket in combination with value
type "Length", a third list is available, allowing you
to choose the appropriate unit, for example "Points",
"Inches", ... Note: The unit displayed in the Default Value field
(lower) depends on the application
Preferences.
| Description | Optionally, provide a brief description. |
to see how the variable will be
presented to the user.
Contents
Copyright ©2018 Enfocus BVBA | All rights reserved.
