If you want to use the preflight and verification functionality of Certified PDF, click to open the Enfocus Certified PDF Panel.
This dialog consists of 5 categories, each allowing you to check a particular aspect of the Certified PDF Workflow:
| Section | What you can do |
| Preflight |
Preflight the PDF using the Preflight Profile of your choice. If the PDF has been preflighted already, you can see the name of the Preflight Profile that was used and the status of the Preflight check indicated by a small icon. Note that this only reflects the status of the preflight, and not of the other aspects of a certified PDF workflow. To view the details, click the Show Result button. |
| Original Documents | Verify the defined original documents. |
| Certified Preflight Profile Comparison | Compare the selected Preflight Profile to other Profiles. |
| Certified PDF Info | |
| Certified PDF 2 Document Certificates | Have the certificates checked for Certified PDF 2 compliancy. |
